amiin85 Posted September 14, 2020 Share Posted September 14, 2020 hi i ve downloaded a symbol its a cnc panel but it has 5 panels i just want one of them im trying to crop it is there any way to do so? thank you Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 14, 2020 Share Posted September 14, 2020 Turn that smoothing angle way up (360 should suffice), use the Delete Surface tool to delete all except the one you want to keep, and then select the object and click Convert Selected To Symbol. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 14, 2020 Share Posted September 14, 2020 Here, I went ahead and did for you as a one time courtesy... CNC Panels.calibz Please Note: This was done in X12, so if you're using an older version you'll have to do it yourself. P.S. Those symbols have a lot of faces. They may bog your system down quite a bit if you use very many of them in the plan. 1 Link to comment Share on other sites More sharing options...
amiin85 Posted September 15, 2020 Author Share Posted September 15, 2020 8 hours ago, Alaskan_Son said: Here, I went ahead and did for you as a one time courtesy... CNC Panels.calibz Please Note: This was done in X12, so if you're using an older version you'll have to do it yourself. P.S. Those symbols have a lot of faces. They may bog your system down quite a bit if you use very many of them in the plan. that is very kind of you thank you sir but where is Delete Surface tool ? sorry i am an amateur Link to comment Share on other sites More sharing options...
rgardner Posted September 15, 2020 Share Posted September 15, 2020 29 minutes ago, amiin85 said: that is very kind of you thank you sir but where is Delete Surface tool ? sorry i am an amateur Try the help search feature in the program. Michael gave you the key word to search for. F1 is a magic little key. Link to comment Share on other sites More sharing options...
