cbdesign Posted September 2, 2020 Share Posted September 2, 2020 Hello, working in Interiors X10 and I consistently have this issue (see attached image). How can I keep drywall where the stud is exposed? Thanks! Link to comment Share on other sites More sharing options...
cbdesign Posted September 2, 2020 Author Share Posted September 2, 2020 Hi Eric, thanks! I attached the plan. I'm not sure what you mean by 'simple plan,' so if I need to do something else please let me know. I am new to the forum! I appreciate the help. I have this problem with a lot of my models. Olson Main_Existing.plan Link to comment Share on other sites More sharing options...
cbdesign Posted September 2, 2020 Author Share Posted September 2, 2020 On 9/2/2020 at 5:39 PM, solver said: Please check your messages. Expand Thanks Eric - I checked my messages and read/watched what you shared. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 2, 2020 Share Posted September 2, 2020 In X10, the easiest thing to do is make those out of Doorways instead of using invisible walls.... fix.planFetching info... Perhaps even better though...just upgrade to X12 and it would be working fine as is. 1 Link to comment Share on other sites More sharing options...
rwdozier Posted September 2, 2020 Share Posted September 2, 2020 I had this very issue just the other day. Turned out to be that I had TWO doorways in the same location. Link to comment Share on other sites More sharing options...
cajunland Posted September 11, 2020 Share Posted September 11, 2020 I have same issue in X12 when using break tool to adjust wall for an extension over a column. I was not able to view Solvers response. See attached file/pic. (PS) I do not believe soffit is viable solution as I am seeing that soffits will not frame. So framing is important. Wall End Issues.plan *Had trouble uploading file. But it was just simple test .plan Thanks. Link to comment Share on other sites More sharing options...
cajunland Posted September 11, 2020 Share Posted September 11, 2020 Re:...issue in X12 when using break tool to adjust wall for an extension over a column. Plan attached now. Forgot a view was open when trying first time. Wall End Issues.plan Link to comment Share on other sites More sharing options...
cajunland Posted September 12, 2020 Share Posted September 12, 2020 Ah! Looks so simple now. I believe I see differences in walls (pony/divider+default wall type ) to make the solution. And looks like they both frame out as needed even better than one wall broken up. I will make separate thread and reference your solution. FYI: I will also post thread for a second floor dormer walls soon. Beaucoup Thanks. Link to comment Share on other sites More sharing options...
