cathedral + coffered ceiling
hieuthuanho
Looks a basic cathedral ceiling with a soffit on the left side.
Open the rooms DBX, go to the structural panel, uncheck Room has Flat Ceiling, which will make it a cathedral ceiling.
Then in the cabinets pull-down select the soffit tool and place it where needed and stretch it out the size you want it.  In elevation or 3D view you can adjust it too.
BTW.. it says you're on X12 and I was going to send you a copy of your plan I modified in X12, but it says you're on an older version.
