chiefjdennis Posted August 22, 2020 Share Posted August 22, 2020 I'm trying to model an A-framed home with flat roof (see photos) with fully exposed foundation with dimensions of 24'x36'. The second floor 36' wall directives are set with two roof pitches (4" & 68") but I modified the steep pitch roof plane with baseline height of 12 5/8" to rest directly on the first floor joist to get the basic house shape. The photos actually show a flat roof so the models upper roof pitch could change to something low like 1/2" Can anyone suggest a method of creating the side dormers which actually extend from the foundation to the roof? When I cut a notch in the steep roof plane to make room for the wall section underneath, it appears to work correctly on the first floor but the entire second floor wall is then visible.Existing_A.planExisting_A.plan I'm able to get a little closer to desired result by breaking up the 2nd floor wall and making "invisible" but I'm still left with the outer section of the wall at what appears to be the floor joist 2nd story floor joist elevation. Any guidance would be greatly appreciated Existing_A.plan Existing_2.plan Link to comment Share on other sites More sharing options...
javatom Posted August 22, 2020 Share Posted August 22, 2020 I did not open the plan but from what you are describing I would make the dormer area a room on floor 1 with a ceiling height set high enough that there is only one wall involved and not a wall from each floor. Link to comment Share on other sites More sharing options...
rlackore Posted August 24, 2020 Share Posted August 24, 2020 I'm not sure this is the best solution: Existing_2.plan There are little slices of roof plane I can't eliminate: Link to comment Share on other sites More sharing options...
