rockyshepheard Posted August 22, 2020 Share Posted August 22, 2020 When placing two windows side by side (both have no casing) What is optimal way to make sure they are as close together as possible with no overlap? How can I eliminate the white gap between them due to not being able to get them touching. Gracias amigos! windows doors.plan Link to comment Share on other sites More sharing options...
glennw Posted August 22, 2020 Share Posted August 22, 2020 You can get them touching. Defaults>Window>General panel>Options>Minimum Separation>change to zero. 1 Link to comment Share on other sites More sharing options...
rockyshepheard Posted August 22, 2020 Author Share Posted August 22, 2020 Thanks again! Link to comment Share on other sites More sharing options...
