ACADuser Posted August 20, 2020 Share Posted August 20, 2020 I can not get the correct combination of setting to make the 2nd floor diaphragm to be all stucco over CMU. It must have something to do with the railings but I can not get the setting correct. I am able to get the correct look above the CMU wall but not over the railing walls. Maybe I'm using the wrong wall type? Vincent Reverse.zip Link to comment Share on other sites More sharing options...
rgardner Posted August 20, 2020 Share Posted August 20, 2020 Like this? Link to comment Share on other sites More sharing options...
ACADuser Posted August 20, 2020 Author Share Posted August 20, 2020 So the only way is to make pony walls on the 2nd floor? Did you do that with the balcony railing wall too? Link to comment Share on other sites More sharing options...
rgardner Posted August 20, 2020 Share Posted August 20, 2020 46 minutes ago, ACADuser said: So the only way is to make pony walls on the 2nd floor? Did you do that with the balcony railing wall too? I only did a quick attempt with that one wall to the right to see if that was what you were looking for, but yes if you do that on the balcony wall as well it should work. just set it to 0 off the floor so it knows that the portion to build between platforms needs to be the pony wall material and everything above the 0" level should be the upper wall. Link to comment Share on other sites More sharing options...
ACADuser Posted August 20, 2020 Author Share Posted August 20, 2020 Thanks, Ryan that solved the problem. Link to comment Share on other sites More sharing options...
rgardner Posted August 20, 2020 Share Posted August 20, 2020 6 hours ago, ACADuser said: Thanks, Ryan that solved the problem. Glad it helped. Link to comment Share on other sites More sharing options...
