DH7777 Posted August 18, 2020 Share Posted August 18, 2020 I saw that this was addressed back in 2015 with a statement that this was a bug that needed to be fixed and was reported. Still not fixed I assume? Cause I can't figure it out...I need one of these curtains to flip. I tried flipping the window but it keeps the curtain forced in one direction. This is pointless to offer a curtain pulled to the side in only one direction. Link to comment Share on other sites More sharing options...
MarkMc Posted August 18, 2020 Share Posted August 18, 2020 Do what Eric says then select the one you flipped, convert to symbol, fixtures interior, hangs on a wall. Now you have it in your library to use as part of the window Link to comment Share on other sites More sharing options...
DH7777 Posted August 18, 2020 Author Share Posted August 18, 2020 33 minutes ago, solver said: Place the curtain as a symbol, not as part of the window. Got it thanks! It worked Link to comment Share on other sites More sharing options...
DH7777 Posted August 18, 2020 Author Share Posted August 18, 2020 7 minutes ago, MarkMc said: Do what Eric says then select the one you flipped, convert to symbol, fixtures interior, hangs on a wall. Now you have it in your library to use as part of the window will do Link to comment Share on other sites More sharing options...
