Clingie Posted August 8, 2020 Share Posted August 8, 2020 Hello, could you please help me with the light behind the cabinet? I started the rendering in X10 and after 7 passes I see the light on the wall, at the physically based view there is none. There is no planned hidden light. Can you please give me some advice how to repair it? Thank you very much. Link to comment Share on other sites More sharing options...
evergreen Posted August 8, 2020 Share Posted August 8, 2020 Please post your plan. Link to comment Share on other sites More sharing options...
rgardner Posted August 8, 2020 Share Posted August 8, 2020 Do you have a floor below or a foundation? Same question with roof or floor above? Looks like light bleed. Finish the model with foundation and roof even if not accurate and see if it goes away. Link to comment Share on other sites More sharing options...
Clingie Posted August 8, 2020 Author Share Posted August 8, 2020 1 hour ago, evergreen said: Please post your plan. please download it here: https://ulozto.sk/file/JQskWvbcYIve/9-8-2020-living-plan thank you for your help. Link to comment Share on other sites More sharing options...
Clingie Posted August 8, 2020 Author Share Posted August 8, 2020 1 hour ago, rgardner said: Do you have a floor below or a foundation? Same question with roof or floor above? Looks like light bleed. Finish the model with foundation and roof even if not accurate and see if it goes away. I´ve had a foundation done and even if I built up the roof, the glow on the wall remains... Link to comment Share on other sites More sharing options...
rgardner Posted August 8, 2020 Share Posted August 8, 2020 19 minutes ago, Clingie said: I´ve had a foundation done and even if I built up the roof, the glow on the wall remains... Other reason that happens is when you have a manually placed item which is penetrating a wall layer. Make sure no manual p-solid or other item is going through the wall. Other than that probably will need to upload the file to figure it out. none of the power users are going to another site to download it to help you though so I would recommend you post the plan file here if that doesn’t fix your issue. Link to comment Share on other sites More sharing options...
Clingie Posted August 9, 2020 Author Share Posted August 9, 2020 12 hours ago, rgardner said: thank you a lot, I finally found the solution. Before I had the cabinet away from the wall layer, but the problem was with the architectural block. It was simply grouped and I should have exploded it... after this the rendering is clear without any weird shades or lights. (sorry for the posting the plan through another site, but the plan exceeded the maximum of 25MB (zipped 46 775 kB)) thanx again. 13 hours ago, rgardner said: Other reason that happens is when you have a manually placed item which is penetrating a wall layer. Make sure no manual p-solid or other item is going through the wall. Other than that probably will need to upload the file to figure it out. none of the power users are going to another site to download it to help you though so I would recommend you post the plan file here if that doesn’t fix your issue. Link to comment Share on other sites More sharing options...
