ACADuser
Can we douplicate the Insulation box object
I was wondering.
Making blocks to simulate (2d detailing) metal framed wall studs, I use a rectangle & 2 interior lines with a short dash line style.
This works well but is there a way to add the punched flat oval or rectangle AND have it stretch line insulation does?
The insulation maintains it's symmetry. Currently, I use several blocks at different lengths & I can stretch them a little without distorting the oval too much.
Instead of using several blocks and stretching them, build one extra tall stud out of 2 separate but overlapping closed polylines....
1128991068_step1.thumb.png.db148804b918bc6974decfa7eb2d02fb.png1861306477_step2.thumb.jpg.791dbfc4622f5e3643d0288de77607dc.jpg
...then simply trim to length using another polyline instead of stretching.  Just group select the main 2, click polyline subtraction, then click the trimming piece...
367819363_step3.thumb.png.aaada03a0f2b27423cbc436d2ca555a5.png1351885346_step4.thumb.jpg.aaa8601cf5f2b892ebd7bd893eedd437.jpg
Thanks for the lesson on pline subtraction.
I suppose I could block the remaining objects so I can make fine adjustments to the length.
Too bad we can not create the Insulation block though.
    28427
    DwightDJ
    DwightDJ
