Convert Auto-Dormer to Editable Parts
kwhitt
I've got several dormers created using the Auto-Dormer tool.  Is it possible to convert these into editable parts whereby I can change the roof to something other than the default?  Thanks,  Kevin
Not exactly sure what you mean by change the roof.... if you mean material though you can just paint it whatever material you want without exploding
7 minutes ago, DzinEye said:
The explode tool only shows up after you select an auto-dormer
Glad you pointed that out.  I was thinking I was to use the explode block tool!  The changes I want to make are to the frieze board styles.  The standard frieze is too large to work at the dormers.  Thanks again!
21 hours ago, DzinEye said:
Sure, you can explode the auto-dormer... but you can signify a different roof type in the dormer dbx too
Mark - when I open the auto-dormer DBX, I have the attached choices to add a frieze, but I cannot change the size of it.  The main roof is using a 1 x 12 for the frieze which is too big for the dormers.  At the dormers I want to use a 1 x 6.  You say you can choose a different roof type, but I don't see where it's possible to change the molding details.  Am I missing something?  Thanks, Kevin
Just now, solver said:
You need to explode the dormer, then add your frieze.
Thanks Eric.  Yes, that's what I was getting at in the original post.  I guess I misunderstood what Mark was saying about being able to change these details without exploding the auto-dormers.  Kevin
Sorry to leave you hanging!   Glad @solver was here earlier to get you straightened out!
You'd originally only said 'change the roof' so I didn't know what that meant exactly, hence I offered several suggestions.
After you'd finally said you were going to change the frieze, I thought you were all set on the path of exploding the dormer so I didn't say anything further!
  • Upvote 2
