ACADuser Posted July 22, 2020 Share Posted July 22, 2020 I've asked this in the past but I will ask again to see if anyone has a solution. I have details (info) on layout sheets in the plan, say Layout label A-10. I will create another layout with my framing plan sent to it. In that framing plan, I have a Rich Text note that says SEE SHEET A-10 for detail or table, etc. I would like to drop a marker (for lack of a better word) on layout sheet A-10 that would update the note on the framing plan as to what layout sheet the marker was on. So if I add sheets to the layout file changing the layout label & the marker is now on A-12 the note would update to say A-12. How can I accomplish such a task? Link to comment Share on other sites More sharing options...
Chopsaw Posted August 5, 2020 Share Posted August 5, 2020 I think I have a solution for you. It is a bit of a work around but may not be so bad once set up in your template. If you use camera labels elsewhere in your layout you may just want to replace that part with regular text either in plan view or layout and then match your text style with the new Camera, Details layer. Link to comment Share on other sites More sharing options...
ACADuser Posted August 5, 2020 Author Share Posted August 5, 2020 Clever solution. I've used it on 3 plans so far. I was able to adjust the text size by changing the layout box scale ILO adjusting the Camera Layer Text Size. Thanks Chop Link to comment Share on other sites More sharing options...
