Jambruins Posted July 7, 2020 Share Posted July 7, 2020 I have inserted windows in the gable end as the house has vaulted ceilings. There is not a 2nd floor. I have inserted some windows in the higher portion of the gable but they show up on the 1st floor plan. I need to put a door on the 1st floor plan where the windows are but the windows are in the way. I tried to put the windows on a separate layer and then turn that layer off but then it leaves a cut in the wall. Any ideas? Link to comment Share on other sites More sharing options...
rlackore Posted July 7, 2020 Share Posted July 7, 2020 Insert the door off to the side of the window, then select the door and drag it into position, or use one of Chief's alignment tools to position the door. Another option is to insert the window in the gable attic wall. Link to comment Share on other sites More sharing options...
tommy1 Posted July 7, 2020 Share Posted July 7, 2020 Go up to the attic level and be sure attic walls are turned on. Place your windows there. Window/s should not show on 1st. floor and should not have a problem placing doors on the first floor. Link to comment Share on other sites More sharing options...
Jambruins Posted July 7, 2020 Author Share Posted July 7, 2020 Perfect, thank you. Link to comment Share on other sites More sharing options...
