Sign in to follow this
jplicc
5 sided window
How do I create a pentagon shaped window in X11.  I can roughly get it using TUDOR ARCH but cant modify it at all, need to match roof pitch. See attached I do not want a center post
What is stopping you?
Yes I can get that far and adjust the height . How do I adjust the pitch of the window?
Change the window width or the arch height.
yes that does adjust it,  I need the width set as it is placed over a slider and im trying to get the pitch to match the roof
Adjust the 'height' in the arch setting
Ive tried both  match roof will create a trapeziod and hieght will not adjust the pitch
Also... if you haven't already sorted it out...
You can make it easier by converting an elevation view to a cad detail and using a couple of lines and take a measurement to get the needed height exactly right
THIS height...
GOT It  Thanks!
GOT It  Thanks!
Good -- Don't forget your Signature :)
    28426
    JosephIM
    JosephIM
