ACADuser Posted November 1, 2014 Share Posted November 1, 2014 In the attached plan I created the floors with the auto floor tool & added walls to the first floor. Wanting the elevator / Lift to be exact I copied the first floor along with the CMU partition wall. Then went to floor 2 & 3 & used paste, hold position. Then the ceiling heights needed to be changed so I use Floor Defaults to change the heights. At this point I added stairs. For some reason the ROOM is not recognizing the wall so the 2nd floor is one big room. On the 2 & 3 floor I deleted the CMU partition & redrew it. That fixed floor 3 but floor 2 is still one large room. How to fix this ? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 1, 2014 Share Posted November 1, 2014 Check your interior wall connections. I don't see any plan attached. Link to comment Share on other sites More sharing options...
ACADuser Posted November 1, 2014 Author Share Posted November 1, 2014 Plan would not upload and jZip will not zip it. I will restart my computer. Link to comment Share on other sites More sharing options...
ACADuser Posted November 1, 2014 Author Share Posted November 1, 2014 OK got it by deleting the CMU partition wall again & re drawing it. Thanks Looks like the copy & past, hold position may have caused the problem. Not sure. All is well now. Link to comment Share on other sites More sharing options...
