robdyck Posted February 18, 2021 Author Share Posted February 18, 2021 8 hours ago, MN_JohnH said: I am having this same problem, weather I have fascia turned on or not, the edit skylight shaft area is grayed out. Skylight problem.plan The 'Ceiling Hole' portion is greyed out because there is no ceiling. This is controlled (that is to say 'removed') by your 2nd floor room 'Open Below'. The skylight appears fine...what would you like to be different? Made some changes for you...take a look. 993208181_Skylightproblem.plan Link to comment Share on other sites More sharing options...
MN_JohnH Posted February 18, 2021 Share Posted February 18, 2021 20 minutes ago, robdyck said: The 'Ceiling Hole' portion is greyed out because there is no ceiling. This is controlled (that is to say 'removed') by your 2nd floor room 'Open Below'. The skylight appears fine...what would you like to be different? Sorry, I guess it looks OK now. When I was doing it this morning the sides of the skylight hole were not covered it was just open into the roof cavity and I thought maybe the ceiling hole would be the answer even on a slope ceiling. But now it looks OK so I don't know what I was seeing earlier. Thanks for the response. Link to comment Share on other sites More sharing options...
