SMC2992 Posted June 17, 2020 Share Posted June 17, 2020 Hey Friends I have used the excellent tool for ceiling in x12, while creating a ceiling it say (recessed) however i want a drop down in the center, but unfortunately i could not find a solution, exvept to make a counter top or poly line solid and raise to required level, can any on help in this, a sketch is attached. Link to comment Share on other sites More sharing options...
rgardner Posted June 17, 2020 Share Posted June 17, 2020 24 minutes ago, SMC2992 said: Hey Friends I have used the excellent tool for ceiling in x12, while creating a ceiling it say (recessed) however i want a drop down in the center, but unfortunately i could not find a solution, exvept to make a counter top or poly line solid and raise to required level, can any on help in this, a sketch is attached. Try the Trey ceiling polyline tool in x12. The bottom portion of your ceiling would be your ceiling height (looks like 8') then you would recess the inner portion 4" up into ceiling. Link to comment Share on other sites More sharing options...
