decorators3 Posted June 16, 2020 Share Posted June 16, 2020 (edited) Hi I am creating a 3D visual for a client but here is my issue the plans I received are in metric so I opted for the metric template BUT the roof plans are regular pitch (ie) 10:12 etc.. How do I change back and forth. I went into Default for Roof Dimensions and opted for secondary format but pitch still shows as metric.. I AM NOT A METRIC PERSON How can I adjust this. Can I change my template and not lose my information if I convert it to imperial Thanks in advance Here are the two different roof specifications ( i prefer the imperial ) the roof plan shows various roof planes . hoping I can get this completed I managed to convert my metric to imperial measures but my roof plane specification is still showing mm any suggestions some of the roof planes are \16:12 14:12 10:12 11:12 Edited June 16, 2020 by decorators3 added additional information Link to comment Share on other sites More sharing options...
Dermot Posted June 16, 2020 Share Posted June 16, 2020 Open the General Plan Defaults and uncheck "Show Pitch as Degrees". Link to comment Share on other sites More sharing options...
decorators3 Posted June 16, 2020 Author Share Posted June 16, 2020 I did as you suggested but still shows as mm Link to comment Share on other sites More sharing options...
Dermot Posted June 16, 2020 Share Posted June 16, 2020 If you change the general plan default, you should be able to specify the pitch as the # mm / 1000 mm rather than as degrees in both the Build Roof dialog and in the Roof Plane dialog. This value will still need to be entered in mm. if you need to convert an imperial pitch into metric, you will probably need to do the math. pitch in mm = pitch in inches / 12 * 1000. For example, 10:12 = 833:1000 See pictures below: Link to comment Share on other sites More sharing options...
decorators3 Posted June 16, 2020 Author Share Posted June 16, 2020 ok thanks Ill try that Link to comment Share on other sites More sharing options...
