PDF print problem
Gawdzira
Other more knowledgeable folks here may have a better answer, but I think it has to do with how Chief is managing fills.
I tried printing with Chief and two of my other PDF printers and all show the same pattern.
FWIW... I exported from Chief as a JPG and it goes away.  You could try setting the PPI very high to get a good output.
Messing around I changed the scale settings you used to bring it into layout and lines went away..
I unchecked "Use Layout Line Scaling" and set it to print 1 to 1... but I have a feeling it's due to the Use Layout Line Scaling
