uvandenb Posted June 1, 2020 Share Posted June 1, 2020 I created a closet with a flat shelf ceiling in a room with vaulted ceilings. In the vaulted ceiling, the ceiling plane has a whole above. While this happens sometimes with my soffits and the holes disappear magically, it does not go away with the shelf ceiling. Any suggestions how to fix this? Thanks! Link to comment Share on other sites More sharing options...
uvandenb Posted June 1, 2020 Author Share Posted June 1, 2020 Melfort_Proposed_Plan.plan Link to comment Share on other sites More sharing options...
javatom Posted June 1, 2020 Share Posted June 1, 2020 FYI. Your stair will not work in that space. You need a bigger stair opening to reach the next level. Link to comment Share on other sites More sharing options...
robdyck Posted June 2, 2020 Share Posted June 2, 2020 19 hours ago, solver said: To fix the problem, open the roof planes and uncheck Use Room Ceiling Finish. This ↑↑↑ Link to comment Share on other sites More sharing options...
uvandenb Posted June 3, 2020 Author Share Posted June 3, 2020 On 6/1/2020 at 12:30 PM, solver said: I've not see that. Could you attach the plan file? Close the software first. Thanks for the suggestion which I followed. However, I am seeing this now. Stairs are still in progress. Thanks, Ute X12 Link to comment Share on other sites More sharing options...
