wall not rebuilding to proper height
MichaelJerome
That's for expansion & contraction, just fill with backer rod and silicone.  :)
Is the bottom of your truss at the height you want?  If so, is your room cln'g ht. set to the proper height?
What's that weird little bit of wall in the floor truss area?
24 minutes ago, MichaelJerome said:
Thanks Ryan - Nice and easy - How does that get unchecked without me physically doing that?
It has to have been manually adjusted (dragged in a 3d or elevation view.
23 minutes ago, solver said:
Try to not manually adjust wall top and bottom heights.
When you do so, the program turns ownership over to you and will not change them to as changes to structure happen.
In general, try to keep everything using defaults. Like the floor structure settings from yesterday.
As Erick wrote let chief work for you.  99.9% of the time the walls do not need to be adjusted manually.
