Cant see the stairs
Scharp
In Plan View (2d), verify that your stairs on on the layer "Stairs & Ramps" and that Disp (display) for that layer is checked. Next, verify that you are on the floor level on which you created the stairs.  In other words, if you want the stairs to go from Level 1 to Level 2, make sure you are currently on Level 1.  They will not appear on Level 2 until you create a "Stairwell" that creates a framed opening through the ceiling.  Also, you must have a "floor" on the second level--not just the "attic".  Hope this helps!
