Enclosing a Corner with Glass Doors
buildinthevoid
I don't think so... but even if it were possible to model it, not sure anyone would build it because the doors would risk hitting each other and breaking.  If you're intent on modeling it you could probably do it using windows.  Here's two casement windows... with no trim, sash or sill
Edited by DzinEye
12 minutes ago, DzinEye said:
Seems to work without it?
You are correct.  No need for the extra wall.  You can just overlap a door and a pass-through in the same wall.  There can be a few little quirks though when 2 openings occupy the same space in the same wall and you also get less control over where the wall lands relative to the wall.
