WildcatFury Posted March 26, 2020 Share Posted March 26, 2020 I have a client that would like to see the door opening size listed on the floor plan in lieu of the Schedule callout number. What is the best (easiest) way to do this? Can we pull other info from the door schedule such as info from the Label column or R/O column? Link to comment Share on other sites More sharing options...
joey_martin Posted March 26, 2020 Share Posted March 26, 2020 Just open the schedule and use the label as the identifier. Link to comment Share on other sites More sharing options...
WildcatFury Posted March 26, 2020 Author Share Posted March 26, 2020 Thanks Eric, I did that but all it did was remove the callout. Joey, That is what I am looking for but I cannot seem to figure out how to use the label as the identifier. Link to comment Share on other sites More sharing options...
WildcatFury Posted March 26, 2020 Author Share Posted March 26, 2020 Eric, No changes to the door labeling, still set up for automatic labeling. Link to comment Share on other sites More sharing options...
WildcatFury Posted March 26, 2020 Author Share Posted March 26, 2020 Eric, When you asked me to create the new plan it worked as you said. So I went back into my plan to see what I was doing wrong and figured out that I had separated floors in the schedules and was turning off the callouts on the wrong floor. So it is now working. Thanks for your help and sorry for the confusion (on my part). 1 Link to comment Share on other sites More sharing options...
