WildcatFury 1 Posted March 26, 2020 I have a client that would like to see the door opening size listed on the floor plan in lieu of the Schedule callout number. What is the best (easiest) way to do this? Can we pull other info from the door schedule such as info from the Label column or R/O column? Share this post Link to post Share on other sites
solver 1582 Posted March 26, 2020 Uncheck Use Callout for Label Share this post Link to post Share on other sites
joey_martin 366 Posted March 26, 2020 Just open the schedule and use the label as the identifier. Share this post Link to post Share on other sites
WildcatFury 1 Posted March 26, 2020 Thanks Eric, I did that but all it did was remove the callout. Joey, That is what I am looking for but I cannot seem to figure out how to use the label as the identifier. Share this post Link to post Share on other sites
solver 1582 Posted March 26, 2020 7 minutes ago, WildcatFury said: I did that but all it did was remove the callout. Have you changed anything in the doors label settings? Share this post Link to post Share on other sites
WildcatFury 1 Posted March 26, 2020 Eric, No changes to the door labeling, still set up for automatic labeling. Share this post Link to post Share on other sites
solver 1582 Posted March 26, 2020 Attach a simple plan that shows the problem. Just 4 walls and 1 door with a door schedule. Share this post Link to post Share on other sites
solver 1582 Posted March 26, 2020 And I assume the Door, Labels layer is on (or whatever layer your door labels are on). Share this post Link to post Share on other sites
WildcatFury 1 Posted March 26, 2020 Eric, When you asked me to create the new plan it worked as you said. So I went back into my plan to see what I was doing wrong and figured out that I had separated floors in the schedules and was turning off the callouts on the wrong floor. So it is now working. Thanks for your help and sorry for the confusion (on my part). 1 Share this post Link to post Share on other sites
