esc hot key only cycles thru last 2 selections
DianeP
According to the info I found I am supposed to have access to 100 previous selections when I hit the esc key.  I am only getting the last 2.  I would like to have around 8, especially when I am setting the electrical objects.  Is there a setting I need to change?
"You can navigate a list of up to 100 recently used tools using the CancelSelection/Previous Command, Next Command and Previous Command hotkeys. The tools in this list are organized according to the order in which you selected them during the current program session."
