Slab Calculation Automation
blueriver
Slabs are  rooms , you can add a room label in each slab area and if you have your room labels set up correctly ( including the square footage macro) it will show. You can also just create your own custom room labels and place them in the rooms, that's the simple way to do it. you can also just create a p-line around the slab area with the area macro included in the label, turn on p-line labels. Many ways to do it.
