SMC2992 Posted March 15, 2020 Share Posted March 15, 2020 Hi friends I am attaching a file wherein i want to open the door shutter outside of the room in such a way that door frame if not visible from inside. How can i achieve this. Thanks room.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 15, 2020 Share Posted March 15, 2020 I read your question three times, I downloaded your file and looked at it and all I can say is "WHAT?" do you wish to do actually? "You want the shutter to open outwards but the door frame not to show.". What, exactly is stopping you from doing so, I wonder? DJP Link to comment Share on other sites More sharing options...
SMC2992 Posted March 15, 2020 Author Share Posted March 15, 2020 Thank you for understanding I actually want that the doors of the rooms should open outside however the door frame should not be visible from inside as i intend to put wall paneling on the interior wall of the walls and want to merge the door in that paneling. As far as 3D is concerned it is no problem but in plan view if i show the door opening outside the door frame is visible in the 3D view from inside. I hope i have made my point clear. Thank you in advance Salahuddin Link to comment Share on other sites More sharing options...
