Plizmo
X12 Send to Layout Dialong Box Help
Is there and up to date help for the Send to Layout Dialog Box.  The Help in the DBX is for X11 not X12.
I am looking for some clarification on the 'Link Saved Plan View () check box.  Basically what it means to be checked and unchecked.
It’s exactly what it sounds like…
If the box is checked, then the layout box will remain linked to that saved plan view.  Any changes to the saved plan view and the layout box changes to suit. If it’s not checked, then the layout box will NOT be linked to the saved plan view.  It will use the same layer set, reference display, floor, etc.  as the current saved plan view, but once sent to layout, the plan view being used will be set to “None”.
Just as an FYI since Michael did a good job explaining the difference, the text in the help documentation is correct but the image is incorrect.  In the future, please report any "bugs" in the documentation to our technical support team the same way that you would report any problems in the program.
    28603
    jerryajohnson35
    jerryajohnson35
