mainst555 Posted March 6, 2020 Share Posted March 6, 2020 Hi, I am having a heck of a time trying to get these roof lines and dormers to work out. I have attached a few shots to show what is going on The two main wall sections (front steep gable and under the gambrel roof) want to be brick. The shed dormer walls want to be stucco. I was able to break and stretch the walls to work (somewhat) but the roofs will not cover the top of the brick. I must be doing something wrong because it just seems like I am fighting with the program. Any suggestions and/or help would be appreciated Link to comment Share on other sites More sharing options...
Signatures Posted March 6, 2020 Share Posted March 6, 2020 Welcome It's helpful to know what software you are using as it changes from version to version. It helps others to have this info in your signature so it's always available. Please see this topic for a signature how to. https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk 1 Link to comment Share on other sites More sharing options...
mainst555 Posted March 6, 2020 Author Share Posted March 6, 2020 Thanks all I am using X11 I tried to upload the file but it is over 25mb Link to comment Share on other sites More sharing options...
Bob-Roraback Posted March 6, 2020 Share Posted March 6, 2020 Did you zip the file? Use back up entire plan command if you did not Link to comment Share on other sites More sharing options...
robdyck Posted March 6, 2020 Share Posted March 6, 2020 To cover that brick you'll need to ensure that 'no special snapping' is checked. Then you can drag the roof line to the sheathing layer or framing layer, or wherever you'd like. For wall materials, don't be afraid to use material regions or even p-solids to accomplish what you need, instead of fighting the wall polyline. Link to comment Share on other sites More sharing options...
