Differentiate ceilings using room divider walls
GeneDavis
I want to change the ceiling in an entry porch from all flat same height, to have a central section raised with a tray rim around.  I've a mix of stick and truss framing above for the roof.
Is it going to be better to divide the space with room divider walls so as to raise up the central section, then do pitched ceiling planes for the four sides of the tray, or should I just not do room division, and build all ceilings with planes.
