Main floor is creating roof through the 2nd floor
fletcher
Hello,
I want to add roof trusses to my plan and leave my manual roof but when I do it builds the wrap around porch roof through the 2nd floor as seen in the images. Is there a way around this or is there a setting I'm missing? I spent several hours yester testing different settings but could not come up with anything that would not build the roof through the 2nd floor.
I am using X7.
Thanks for your help.
PJ_&_Krisha.plan
Glenn,
I am using the auto-build roof function image.png.b379cb1ba4b2d7d2d58241f8938d65ef.png. I custom built the back patio and don't want it deleted so I check the following boxes in the image below.
Eric,
I am not manually drawing trusses. I am just selecting the Trusses box under the specifications section in the dialog box. Is that what you mean?
As an FYI it does this whether I select trusses or not. Like I said I spent several hours last night systematically trying all the checkboxes to see if I was missing something but every time it builds the roof through my second floor.
