dormer walls missing shingles
LouFabb
59 minutes ago, LouFabb said:
Any help would be appreciated, thanks. Lou
You appear to have a un-needed Roof opening on the 1st floor over the fridge , so I pulled it out onto the backyard.
It's a bit finicky but I then made both sidewalls  - roof cuts wall at bottom and reshaped them in 3D
This will leave a hole in the drywall each side , which I fixed with a short piece of interior 4 wall marked  - No Room Definition -  and slide into place.
*** edited for typo No Roof Def.  was supposed to be   No Room Def.
Mick.
image.thumb.png.3ef4478bb08855fe1161e4ae639cf8e8.pngimage.thumb.png.1858f6a8f7217df2ffda19ca24518580.png
8 minutes ago, LouFabb said:
Kbird1,
Finished one side and have a small issue, when I reshaped in 3D I am left with a vertical line in the siding see jpg.
Still two seperate walls? make it one wall then.... marked Roof cuts wall at bottom.
Mick.
