rockyshepheard Posted February 9, 2020 Share Posted February 9, 2020 See illustrative view. CA file attached. And if that's too easy for you, how is it possible that deleting an object could change wall material (all the way around the house) to the default? Thanks Gurus! R gilkey close.plan Link to comment Share on other sites More sharing options...
rockyshepheard Posted February 9, 2020 Author Share Posted February 9, 2020 I noticed I have no working plan view menu or annotation menu. This could be related. Link to comment Share on other sites More sharing options...
Mark3D Posted February 9, 2020 Share Posted February 9, 2020 you have lost your room definition but to fix it you need to unlock the layers and turn them on in floor plan view then check your walls out the see were the problem is Link to comment Share on other sites More sharing options...
