See wall materials in 3D view
skirby19
X11 Build 21.3.1.1x64
When in 3D view, the materials within the walls/roof show. Some kind of a glitch and I can not figure this one out. Attached is the file. See if it does the same for you. Let me know if you can see what I may have inadvertently done.
Thanks for the help. -Steve
Update: Trying to upload the 12mb file and it gives me this error...
There was a problem processing the uploaded file. -200
Update:
I get this error when opening the file now.
c:\p4sync\dev\releases\21\chief\camodel\plan\document.cpp(3361): Warning #272032643
"1080 object(s) are too far away from the origin in "Site Plan2.plan". You can delete them, or try to move them closer to the origin, but they will not keep their position relative to other objects in your plan."
2/3/2020 10:07:49 AM
Build: 21.3.1.1x64
11 hours ago, skirby19 said:
Ok that does work and yes it moves about 50% of the doors, electrical...Hopefully this doesn't replicate in the future. This is a first.
It's a known problem and is called Z-Fighting , and occurs as Eric pointed out when you draw a Building a LONG way from 0,0  on the coordinate grid ( see your Status Bar.)
to help eliminate the Issue in the future, place a Point in your New Plans Template at 0,0 ( use input point tool )  move the view so the point to the bottom left corner and then save your template. Now when starting a new drawing , you know at a glance you are close to 0,0. and shouldn't have these issues.
https://www.chiefarchitect.com/support/article/KB-00107/troubleshooting-why-materials-appear-to-flicker-when-a-camera-view-is-rotated.html
