Bob-Roraback Posted January 28, 2020 Share Posted January 28, 2020 The help manual states that in the default sets dialog you should be able to copy a default set by clicking the copy button. I do not see a copy button when I open the default sets dialog. Did this function get omitted by error? or is the help manual written incorrectly. From the manual, Creating Default Sets There are two ways to create a new Default Set: • Click either the New or the Copy button in the Default Sets dialog. • Click the Save Current Active Defaults button in the Active Defaults dialog. Link to comment Share on other sites More sharing options...
glennw Posted January 28, 2020 Share Posted January 28, 2020 The way it works is that if you select New, it makes a copy of the existing selected Default Set in the list. So no need for a copy button - each New Default Set is a copy of an existing one. And yes, the documentation needs an update. 1 Link to comment Share on other sites More sharing options...
wjmdes Posted January 28, 2020 Share Posted January 28, 2020 4 hours ago, glennw said: The way it works is that if you select New, it makes a copy of the existing selected Default Set in the list. So no need for a copy button - each New Default Set is a copy of an existing one. And yes, the documentation needs an update. Thank you... I was looking for that the other day! Link to comment Share on other sites More sharing options...
Bob-Roraback Posted January 29, 2020 Author Share Posted January 29, 2020 Understood. Thank you Glenn! Link to comment Share on other sites More sharing options...
