rockyshepheard Posted January 2, 2020 Share Posted January 2, 2020 Hi Everyone. I would like to avoid doing the (create 2D cross section/draw CAD line/create polyline solid/convert to molded polyline), just so I can place a simple rectangular prism above a window ...specifically...Window Specification/Treatments (exterior millwork above casing) CA-001 shows up when I browse the library. This would work but it is not available as a Window Specification/Treatments library options. The closest I can find is Architectural/Millwork/Mantels,Lintals, & Sills/Striaght/Angled Header. It has six sides but two of them are angled. I also am trying to avoid adding a custom rectangular prism as I am doubtful it will show up under the treatments menu. Does anyone know of a window treatment library option under Windows Specification/Treatments/exterior millwork above casing) that is a rectangular prism? Thanks! Link to comment Share on other sites More sharing options...
glennw Posted January 2, 2020 Share Posted January 2, 2020 Millwork>Cabinet Feet>Straight Feet? Link to comment Share on other sites More sharing options...
