CUBRAD Posted December 23, 2019 Share Posted December 23, 2019 When sending a drawing to the layout, it changes drawing on all layout pages to what was just sent. It just started doing it on chief 11 How do I fix it?. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 23, 2019 Share Posted December 23, 2019 Are you using a "Saved Plan View"? If so, be sure to create a "New Saved Plan View" before sending to Layout. When you edit a "Saved Plan View", all instances of that will be the same in the Layout. Floor Layer Set Defaults Zoom Factor Scale Can all be problematical unless you use separate "Saved Plan Views". Link to comment Share on other sites More sharing options...
Evolution Posted December 23, 2019 Share Posted December 23, 2019 Check to see if you are doing "saved plan view"? NEVER MIND....what Joe says! Link to comment Share on other sites More sharing options...
