GVBDerin Posted November 28, 2019 Share Posted November 28, 2019 Is there a way to manually edit dimensions after they have been drawn? With CAD I used to be able to click on a dimension and manually edit the measurement. Just can't seem to find a feature like that in Chief. Thanks in Advance! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 28, 2019 Share Posted November 28, 2019 Are you trying to change the dimension's text or change the actual dimension to make something larger or smaller? Link to comment Share on other sites More sharing options...
GeneDavis Posted November 28, 2019 Share Posted November 28, 2019 That function is available in other CAD packages but in Chief you need to work around it with a patch. In the two images, you can see the dimension as generated, the patch, and the patch moved to cover the true dimension. Link to comment Share on other sites More sharing options...
