Designer100 Posted November 22, 2019 Share Posted November 22, 2019 This is just a remodel on exterior and new outdoor kitchen. But I cannot get the circle wall that is going into the living area inside the house by outdoor kitchen. I cannot get it deleted out. I would appreciate anyones help. Newell 713.385.3622 newell@newellcheatheam. Bolding_Tony.Sarah_Remodeling.plan Link to comment Share on other sites More sharing options...
StephenGreene Posted November 23, 2019 Share Posted November 23, 2019 there is a room divider that is causing your problems. remove it and the odd circle wall disappears. 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted November 23, 2019 Share Posted November 23, 2019 6 minutes ago, StephenGreene said: there is a room divider that is causing your problems. remove it and the odd circle wall disappears. Nice Work Stephen. There is more than just one thing wrong there. Why a connected exterior wall cannot maintain the room definition defies explanation. Unless someone has a reasonable explanation for this behavior it should likely be sent in to tech support for analysis. Link to comment Share on other sites More sharing options...
StephenGreene Posted November 23, 2019 Share Posted November 23, 2019 1 minute ago, Chopsaw said: Nice Work Stephen. There is more than just one thing wrong there. Why a connected exterior wall cannot maintain the room definition defies explanation. Unless someone has a reasonable explanation for this behavior it should likely be sent in to tech support for analysis. thanks, Chop. i replaced it with a porch beam and it worked fine. no idea why it wouldn't work with a room divider. 1 Link to comment Share on other sites More sharing options...
Designer100 Posted November 25, 2019 Author Share Posted November 25, 2019 Thanks for the help 1 Link to comment Share on other sites More sharing options...
