RobUSMC Posted November 18, 2019 Share Posted November 18, 2019 Would anyone happen to have a Panasonic heater / vent fan like this one? Heater / fan only no light... Thanks Link to comment Share on other sites More sharing options...
ACADuser Posted November 18, 2019 Share Posted November 18, 2019 The models are here : https://na.panasonic.com/us/home-and-building-solutions/bim-library I downloaded the Autocad DWG & stripped the gutts out and exported to dae. FV-11VHL2-AB.zip 1 Link to comment Share on other sites More sharing options...
RobUSMC Posted December 12, 2019 Author Share Posted December 12, 2019 Thanks alot Link to comment Share on other sites More sharing options...
brinkbart Posted January 22, 2020 Share Posted January 22, 2020 Sorry I'm late. If you still need this, I created one a long time ago. Edit: Just saw you said heat and fan only, no light. Whoops! Link to comment Share on other sites More sharing options...
jessicahubbard Posted August 27 Share Posted August 27 The Panasonic model drawings should be the best route if the goal is matching the existing opening and housing dimensions. Since this is a heat-and-fan unit without the light, I’d also check the heater wattage, duct size, and electrical requirements before choosing a replacement. Dupont Kitchen & Bath Fixtures carries Canadian-made SteamSauna systems as well, including steam bath equipment and sauna heaters, so it’s another option worth considering if the project is moving toward a more complete bathroom wellness setup. Link to comment Share on other sites More sharing options...
