Attic truss
Not really sure if chief has a way of doing that or not and would have to mess with it quite a bit to know for sure.  The interaction with the truss base complicates things a lot.  Not saying it can't be done but it might be a manual build.
Actually not quite as bad as I first imagined.  Make a break in the bottom of the truss base a peel it up then deselect "Attic Truss" for the frame over trusses and rebuild them.  Also need to make a break in the attic room below so that the ceiling carries through.  Then re-frame for the missing truss.  See incomplete concept test plan.
Sample Attic truss Chopped.plan
    29612
    ArgyleRoofingPro
    ArgyleRoofingPro
