Dormer Help
kwhitt
Thanks Eric.  The dormer walls are already connecting to the interior walls as shown in the second image.  I thought CA would fill this in automatically.  I'm not sure I understand what you mean by drawing walls that cover the gap.  There are already walls drawn in these locations.
Thanks again Eric.  Where did that wall come from?  Is it something you drew or by changing the roof setting it will automatically connect?  Sorry, I still don't follow.  I tried to change the roof settings as you show in your images and the results are still the same.  Would you mind sharing the revised file?  Kevin
4 hours ago, kwhitt said:
I am attempting to model my first dormer.  I can't get the side walls to connect - see attached.  I would greatly appreciate any help with this.  I have attached the plan file too.  Thanks,  Kevin
Baker_As-Built_07-26-19.plan
You might check out my videos on dormers...this is an oldie but covers a lot.  Hope it helps...dormers can be quite frustrating.
