LeeDrafter Posted September 4, 2019 Share Posted September 4, 2019 Hi All, I am trying to achieve a ray trace with a tree in the foreground that sort of frames the picture. Attached is an example of my goal- I did not create the attached jpg. I am getting close by placing a tree close to the camera but mostly out of view, but every tree I have tried is blurry. See the saved camera in the attached file. Then I place another big tree closer to the house to create a shadow on the house/driveway. I will crop that tree out of the final picture. Are there any trees CA has that you recommend for close-up high resolution (5500x3200 pixels) ray trace? I found a thread from the old Chief Talk where they had a similar problem and Larry Kumpost suggested a high res tree, but I don't know where to find one. Here is the old thread http://www.chieftalk.com/showthread.php?34289-Exterior-Critique&highlight=trees+foreground. Thank you in advance! THE ADLER RENDERING.zip Link to comment Share on other sites More sharing options...
Renerabbitt Posted September 4, 2019 Share Posted September 4, 2019 On 9/4/2019 at 9:06 PM, LeeDrafter said: Thank you in advance! Expand I would suggest using a 3d tree from the bonus catalog, free with SSA. Alternatively, you can turn any image into a tree if it is a PNG with no fill in the background.Do a google search. build/image/create image- load your tree texture. Link to comment Share on other sites More sharing options...
mattyt12 Posted September 4, 2019 Share Posted September 4, 2019 alternatively you could add a hanging tree png in a photo editing program, not a real good example was a 30 second job importing images in layout but you get the idea. Link to comment Share on other sites More sharing options...
LeeDrafter Posted September 4, 2019 Author Share Posted September 4, 2019 Thank you both, these are great suggestions! I will try all of these methods. I don't have experience with photo editing, but I am starting to dabble in GIMP to crop my renderings to specific sizes, so I have some more learning to do :). Thanks again Link to comment Share on other sites More sharing options...
