Adam_Gibson Posted August 29, 2019 Share Posted August 29, 2019 Anyone know the quickest way to make a window like this top one? I'm stumped on the triangular part. It's a 12/12 pitch. Link to comment Share on other sites More sharing options...
Catch22 Posted April 10, 2023 Share Posted April 10, 2023 Thanks Eric. this helped me today. I wish I'd searched here first. I spent quite awhile today on You tube with no luck. Your solution was so simple and easy. Link to comment Share on other sites More sharing options...
JKEdmo Posted April 11, 2023 Share Posted April 11, 2023 Indeed a helpful tip. I also struggled with defining a triangular window recently. If I recall correctly, I instead fussed around in the "shape" category with window side heights... I never thought about an arch setting with zero radius. Why? Because in the real world a triangular window is not arched I suppose. I think this is a good example where Chief could make things a little more user friendly and accessible to the user not wise in arcane workarounds. Maybe add a window shape called triangular? No snark intended. Just my two cents. I am pretty impressed with what you can do with Chief. But, sometimes it seems things are a little mysterious and hidden. Jim 1 Link to comment Share on other sites More sharing options...
NewLeafHomeDesig Posted May 26, 2023 Share Posted May 26, 2023 Thank you all for this! JKEdmo's comment about the arch with zero radius helped me see what the key was here. Besides the full triangle in the intial post, you can also use this to create a window with 5 sides: two vertical perpendicular to the horizontal, and then two at the angle to match the ceiling line. Though you do have to play with the dimensions to match the ceiling rather than it being automatic. Link to comment Share on other sites More sharing options...
