kwhitt Posted August 13, 2019 Share Posted August 13, 2019 I have a sunken floor in a great room. Where the lower floor meets the higher one, there is no wall behind the baseboard as can be seen in the attached image. I followed the video "Dropping a Floor and Raising the Ceiling of a Room" and used an invisible wall as instructed. I'm sure it's a setting in the wall properties, but I am unable to find it. I'd appreciate some help with this. Kevin Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 13, 2019 Share Posted August 13, 2019 On 8/13/2019 at 6:18 PM, kwhitt said: I have a sunken floor in a great room. Where the lower floor meets the higher one, there is no wall behind the baseboard as can be seen in the attached image. I followed the video "Dropping a Floor and Raising the Ceiling of a Room" and used an invisible wall as instructed. I'm sure it's a setting in the wall properties, but I am unable to find it. I'd appreciate some help with this. Kevin Expand Would use a half wall and adjust the height according to your sunken floor elevation. You can do this after the fact by designating your invisible wall as a railing in the wall dbx. general tab and in rail style tab set it to solid. Then designate the height in the newels/balusters tab 1 Link to comment Share on other sites More sharing options...
kwhitt Posted August 14, 2019 Author Share Posted August 14, 2019 Thanks Rene. Link to comment Share on other sites More sharing options...
