jheath21 Posted August 6, 2019 Share Posted August 6, 2019 I'm working on this project for a summer class.. I'm finished and was taking perspectives and a couple ray trace. I changed some of the settings in the ray chase for lights and such, and then I move to another part of the building and the ceiling is gone!! What did I do wrong? And how do I fix it?! Please help!! I attached a snap of the outside of the building...no ceiling in the center (also I know my glass panels extend above the ceiling don't judge me) Link to comment Share on other sites More sharing options...
Chopsaw Posted August 6, 2019 Share Posted August 6, 2019 It appears you do not have a roof but if all you need is ceilings for now. Open the affected rooms and under the Structure tab of the Room DBX go to Ceiling and select "Flat Ceiling Over This Room" Not quite sure how you got there but that should fix it unless the Ceiling Finish was deleted. Link to comment Share on other sites More sharing options...
jheath21 Posted August 7, 2019 Author Share Posted August 7, 2019 20 hours ago, Chopsaw said: It appears you do not have a roof but if all you need is ceilings for now. Open the affected rooms and under the Structure tab of the Room DBX go to Ceiling and select "Flat Ceiling Over This Room" Not quite sure how you got there but that should fix it unless the Ceiling Finish was deleted. Thank you! That fixed it! Link to comment Share on other sites More sharing options...
