Trey Ceiling
RussellHouse
2 hours ago, DavidJPotter said:
By Trey Ceiling do you mean stepped (like in the video I just did) or do you mean coffered (slanted at the edges of the room?
If you meant coffered then I need to do another video :)
Trey- stepped.  For some reason the standard ceiling still appears in 3d and noy showing the Trey
If your using David's method and your not seeing they trey (soffit), then check the height of the ceiling in relation to the height of the soffit. Also be sure you have cabinet soffits turned on in the layer display.
