lbuttery Posted July 24, 2019 Share Posted July 24, 2019 I have tried to get these 3 images to be as large as possible but even with setting "front" and "back" if I make them any larger the bounding box starts to overlap the actual image is there any way to hide the bounding box completely ? done in X9 Lew OAKWOOD_NOTABLES_24X12_190724_1300_LBX9.layout Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 24, 2019 Share Posted July 24, 2019 1 hour ago, lbuttery said: is there any way to hide the bounding box completely ? Bounding box is separate from the issue here, PNG files allow for transparent backgrounds, your source file is a jpg and does not have a transparent background...You may need a photo editor to delete the white background and save as a png..then make sure png is check in the image dbx within CA Link to comment Share on other sites More sharing options...
lbuttery Posted July 24, 2019 Author Share Posted July 24, 2019 Rene: ok, I will try to learn how to convert .JPG to .PNG with transparent background thanks Lew Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 24, 2019 Share Posted July 24, 2019 7 minutes ago, lbuttery said: Rene: ok, I will try to learn how to convert .JPG to .PNG with transparent background thanks Lew If you wanna post the images I can do it for you very quick Link to comment Share on other sites More sharing options...
