djhplanning Posted July 15, 2019 Share Posted July 15, 2019 Would anyone know if it is possible and how I would change the door tags on the door schedule to letters instead of numbers. My window schedule has numbers so I don't want to confuse things with numbers on the door schedule as well. Link to comment Share on other sites More sharing options...
djhplanning Posted July 15, 2019 Author Share Posted July 15, 2019 And how do I keep an exterior sliding glass door from showing up on the window schedule and also on the door schedule? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted July 15, 2019 Share Posted July 15, 2019 47 minutes ago, djhplanning said: how do I keep an exterior sliding glass door from showing up on the window schedule and also on the door schedule? Open the Schedule you don't want it to show on and uncheck it in "Items to Include". Link to comment Share on other sites More sharing options...
djhplanning Posted July 15, 2019 Author Share Posted July 15, 2019 24 minutes ago, Joe_Carrick said: Open the Schedule you don't want it to show on and uncheck it in "Items to Include". Thanks Joe, this worked to uncheck the sliding glass door off of the items to include. I would normally include exterior patio doors in the window schedule because they are normally supplied by the same window manufacture as the other windows. But in this case I also have an outswing French door in a different level of the house. It would be nice to also have that option for outswing French doors as well and not only for sliding glass doors. Link to comment Share on other sites More sharing options...
djhplanning Posted July 15, 2019 Author Share Posted July 15, 2019 1 hour ago, solver said: What is a "door tag"? The default door schedule uses a D prefix on the number, and the window schedule uses a W prefix so they show differently in plan. Thanks Solver, A door tag is what Chief calls a label on the floor plan. I like to use a number for my windows (when I use Chiefs window schedule). If I don't use Chiefs window schedule, I just show a generic window size on the floor plan (i.e. 2'6"x4'-0"). For doors, I usually show the door label on the floor plan i.e. 2668 (2'-6" wide by 6'-8" high) and don't even use Chiefs door schedule. For a current project, I did need to use the door schedule because I needed to show an exterior out-swing French which will not go to a window schedule. I like to keep things simple and have sometimes used letters before for door labels. I don't like using the default D and W before the label because the symbol gets to big (because I like to keep all of my text, including labels the same 5" size). Apparently numbers is the only option for both window and door schedules. Link to comment Share on other sites More sharing options...
