Auto interior dimensions
Christhebuilder
51 minutes ago, Christhebuilder said:
I don't have the option for auto interior dimensions available in the dimension drop down menu. Am I missing a setting that makes its available? Auto exterior is there, NKAB is there, Just not auto interior. What am I missing?
It has been changed to a room only option.  When you select a room, you will
see auto int dim in the edit menu.
All rooms at same time was too much.
it still works for all rooms, i have auto interior dimensions in my toolbars and it works as it always did
Why would you want it to ?  Every room gets about 6 strings....
I prefer room by room.
specifically for takeoffs and electrical.
I have my auto interior dims set on a layer called takeoffs and a very light grey dimension string. when I select on an architectural component to adjust its location CA uses the color I've set to highlight the dimension strings that can control that architectural feature. It's a very efficient way of doing as-builts for me.
I have auto interiors in my electrical set to find electrical fixtures...works well for me.
Notice the light grey dims that are not active when selecting a wall to be moved...when I'm done, I turn off the takeoffs layer:
Nice.  Things to try.
Thanks
